		2015-12-09
		10:39 PM
		2023-05-26
		02:26 AM
			Gordana Radonic
2015-12-09 11:14 PM
2015-12-09 11:19 PM
vgodzb wrote:
Why don't you rotate the view before placing it in the layout, instead of rotating the view in the layout?
2015-12-10 12:04 AM
rob2218 wrote:
OK, I guess I should have mentioned that "that view" is coming from the model itself. it's not a clipped detail 2D linework view...it's merely an enlarged view of the entry with a different layer combo, different penset, etc...but I can't very well rotate the entire model now can I?
I just need that detail marker head to be able to be rotated 90 degrees counterclockwise is all.vgodzb wrote:
2015-12-10 12:08 AM
2015-12-10 12:31 AM
vgodzb wrote:
First check the settings in the detail.
Go to Marker Geometry > Marker Head Rotation > Always Horizontal
Then make another view and rotate it 90 degrees, save that view as such then place it on the layout.
2015-12-10 12:41 AM
2015-12-10 02:53 AM
2015-12-10 04:23 AM
2015-12-10 03:44 PM
