Llian
DIMENSION STRING
Where can i have dimension option for slanted lines? i've clicked on the attached [looked like it does for slanted/diagonal lines/objects] but it is constraint vertically or horizontally.
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
6 Replies 6
Llian
this is what i mean...the dimension string doesn't align with the 2 slanted lines??
Did you click on the angled button before placing the dimension? You can't change a dimension in this way after it is placed.
Llian
Yes... i selected the angled button, then select the 2 dashed lines and placed...and still get this horizontal string...
Rod Jurich
Llian wrote:
Yes... /......and still get this horizontal string...
Now where did you click first off?
At some horizontal point on your 2 lines or the ends?
See attached.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Llian
thanks...strangely, i don't see the display ...oops did i mess up the settings?
Rod Jurich
3 differing results depending where you click on your lines.
I'd also suggest spending a little time with the reference manual
Rod Jurich
