DRAWING VIEW ON LAYOUT SHIFTING EACH TIME VIEW SETTINGS UPDATED
I am having an issue with Views placed on sheets.
Every time I update a view's settings (I use the 'Get current windows settings' works well for me workflow wise) in a view, unless I have opened the view specifically, and updated the settings (MVOs, layers etc) without moving the view's on screen visible area, when I go to the layout that a view is placed on, the view has moved its visible area (anchor point?) and I have to realign the view to fit back to its original location on the layout sheet.
I am not sure whether this issue has resulted in either a new template I am using (packaged AU template built to suit practice where I work) or with the upgrade from 21 to 22.
Surely there is a simple answer to this, but it has been plaguing me incessantly and costing a lot of time and any help would be much appreciated!
Thank you
1 REPLY 1
Erwin Edel
You can set 'Use Internal Origin' as anchor point and will keep referencing the origin of the project for each placed view.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
