svpribyl
Design Options are not available in View Settings
I have one design option set up, along with the Main Model. However, it the custom design option is not available in the View Settings. Only the Main Model is available to set in the View Settings
Operating system used: Mac Intel-based
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
1 Solution
hevi
Ace
You need to create a Design Option Combination as it - and not individual design options - is you set for the view.
Go to post
2 Replies 2
hevi
Ace
Hi @svpribyl,
I think in your case you can go further for creating a new DO combo as @hevi suggested or rather you can:
1) Select all elements & objects inside Option 1 then click on Main model then Relink.
2) Create a new Reno Filter & name it Option 1 then assign all elements & objects inside that DO into the newly created filter & activate Option 1 Reno filter in view settings dialogue.
AC 29 INT 4006/WIN 11
