SOLVED!
Detail layout ID not updating
sknsnw9
The layout ID isn't updating when I make new details. It references to sheet to 6.3 when it's actually on sheet 6.1. Any help to get that to automatically update? I tried to change some settings around, perhaps I'm not looking in the right place.
Operating system used: Windows 10
Archicad Solo 24 - 28 : Windows 10 Pro 64-bit : 16 GB ram / Intel Core i7-4770k @ 3.50GHz : NVIDIA GeForce RTX 3060 / MacBook Pro M3 Max
1 ACCEPTED SOLUTION
Solution
You are linked to the 'first placed drawing'.
Are you sure you don't have that detail placed on another layout as well?
Set it to link to 'selected drawing' and then select it from the list.
3 REPLIES 3
Solution
Ah, I see what the issue is now. I have the details prepopulated on other sheets in my template, I deleted those since I didn't need them anymore. Updated and it now works. Thanks Barry.
Diseno14
When I have a first detail located in a plan, elevation, or section and I place a second detail by dragging a copy of the first, I have had this problem. It's better not to do it this way.
Lpalma
Setup info provided by author
