2024-03-13 08:58 AM
The Fill Pattern of Insulation - Mineral Soft works great on Floor Plan view.
But It does not fit to skin in Section View.
How can I fix it?
Solved! Go to Solution.
2024-03-13 09:13 AM
I suppose that you should be using a composite wall, even if it's made of just one layer. Otherwise you cant use the Fit to Skin option in the building material settings.
2024-03-13 09:25 AM
As Xandros mentioned, it seems it needs to be a composite or complex profile wall for the fit to skin to work in section.
2024-03-13 09:12 AM - edited 2024-03-13 09:12 AM
Make sure your insulation building material has the fill orientations set to 'Fit to Skin'.
2024-03-13 09:13 AM
2024-03-13 09:18 AM
my fill orientation is already set to 'Fit to Skin'.
2024-03-13 09:19 AM
'Fit to Skin' option works good on Floor Plan. but, not on Section view.
2024-03-13 09:25 AM
12 hours ago
It's frustrating though. I see no reason why it shouldn't work on monolithic walls or slabs too.
