ā2012-01-25
07:03 PM
ā2023-05-30
12:28 PM
Rubia Torres
ā2012-01-25 07:03 PM
ā2012-01-25 08:19 PM
Richard wrote:This is controlled by the Section tool settings. You have the option for each section to specify how the cut elements are displayed. If there is no check in the box for 'uniform pen for cut elements', the each cut element uses its own pens and fills - including whatever color you specified as the fill background color. If you check the box for uniform pen - then you can specify the pen (color and width) for the cut contours - and the pen (color and width) for both the fill and the fill background.
- How to I make the background of the section white instead of grey in the walls?
ā2012-01-25 08:28 PM
Richard wrote:To have the insulation fill follow the direction of the skin that it is in, you must use a 'symbolic' type fill and choose 'fit to skin' as the skin fill orientation as shown in the attached screenshot. It is a shame that this feature does not work with vectorial fills, so you may have to construct your own symbolic fill.
- Can I scale the hatching and choose the direction? I want to get the insulation pointing in the right direction and scaled to fit properly.
ā2012-01-25 08:38 PM
ā2012-01-26 10:15 AM
ā2012-01-26 05:08 PM
Richard wrote:Still 2D, but there are several libraries of 2D parts to speed up detailing - basically stamping parts onto the view, with some parts being parametric.
Would you happen to know of any good plugins which would allow me to produce a good detail without all the 2d drawing?
