Different Thickness walls not intersecting
onestoreyllc
I have two thicknesss of walls with the same composite buildup and the same junction order, same strength of materials.  The walls are the same height in the same story and same layer.
Meredith
AC26 USA - Lenovo P17 - Intel(R) Core(TM) i9-10885H CPU @ 2.4GHz - 32.0GB - Windows 11 Pro
5 REPLIES 5
onestoreyllc
Also here
Meredith
DGSketcher
Legend
Check your on screen view options especially Clean Wall & Beam Intersections.
thanks, my view options are set with clean wall and beam intersections on and thise is still the result
Meredith
DGSketcher
Legend
You may be on the same layer, but if the answer above didn't work then you need to look at your LAYER INTERSECTION SETTING
Lingwisyer
Guru
This cannot be 0
