Paul Roper
Dimension Text Background Opacity
Hi all,
I've just installed Archicad 27 3001 NZE Full.
I've noticed that when I create a Dimension object, with Text Style set to have an Opaque background, the text box appears behind the dimension line (as per attached image).
This behavior is not what I have come to expect. Is there a toggle or option I am missing?
I am aware of the Within Line option, but this is not what I am looking for as it does not behave as I would expect with my current workflow (for example: if I want to manually relocate the text box due to clashes with something else in the drawing).
I tried to edit the Display Order, but this setting does not appear to apply to Dimension text boxes.
AC27 5003 INT | i511400F | 32GB | GTX1650
1 Solution
Select the dimension line and not just the text and there will be a display order setting.
Go to post
2 Replies 2
Paul Roper
Yes, that's it.
Thank you, Barry!
