2024-05-08
04:52 AM
2024-07-10
12:43 PM
Aruzhan Hamar
Hi all,
I've just installed Archicad 27 3001 NZE Full.
I've noticed that when I create a Dimension object, with Text Style set to have an Opaque background, the text box appears behind the dimension line (as per attached image).
This behavior is not what I have come to expect. Is there a toggle or option I am missing?
I am aware of the Within Line option, but this is not what I am looking for as it does not behave as I would expect with my current workflow (for example: if I want to manually relocate the text box due to clashes with something else in the drawing).
I tried to edit the Display Order, but this setting does not appear to apply to Dimension text boxes.
Solved! Go to Solution.
2024-05-08 05:30 AM - edited 2024-05-08 05:30 AM
Select the dimension line and not just the text and there will be a display order setting.
2024-05-08 06:20 AM
Yes, that's it.
Thank you, Barry!
