ā2008-10-21
07:16 PM
ā2023-05-30
03:18 PM
Rubia Torres
ā2008-10-22 12:50 AM
ā2008-10-22 12:51 AM
ā2008-10-22 01:27 AM
geircito wrote:I guess this where we are having problems! In ArchiCAD you are always drawing full size, but text, linetypes, hatches, dimensions, labels, doors and windows are all sensitive to the specific outputting scale, and will adapt themselves accordingly.
In Microstation I ALWAYS draw in scale 1:1
ā2008-10-22 01:35 AM
Peter wrote:No, the text size, dimension lines & dimension text stays exactly the same, both on 1:100 and 1:20, and both displays very very fine, both onscreen and when printed (se my pictures from Microstation in my earlier post).
What happens if you have some text that displays fine at 1:100, but when you create a room layout at 1:20 surely the text would appear enormous!
ā2008-10-22 01:45 AM
ā2008-10-22 04:29 AM
geircito wrote:The dimensions don't have that switch - I meant the text, and the zones, as you already found out.Djordje wrote:So I ask again, where is the switch in the dimension tool that I search for?
There is also a switch for this...
Or is it "impossible"?
