2006-05-17
02:44 AM
2023-05-30
03:24 PM
Rubia Torres
2006-05-17 12:41 PM
2006-05-17 04:47 PM
2006-05-17 04:56 PM
Jere wrote:I wish I had an answer for that question that did not involve sarcasm, humor, or Murray-esque snarkyisms.
Why doesn't ArchiCAD have these simple adjustments?
2006-05-17 05:16 PM
TomWaltz wrote:I heard that.
snarkyisms.
2006-05-17 05:44 PM
Jere wrote:I have been wanting leader lines to align with the center of the first line of text for as long as I have been using Archicad and I know it has come up as a wish multiple times. Maybe in 11 Graphisoft can fix what appears to be a very simple problem that prevent some people (graphic snobs) from using the label tool. I use the label tool and hope I have mostly single line text
thanks for the reply.
That's quite dissappointing to hear though. Same with leaders I suppose? I want to change how the text lines up with the leader line. The only options are top aligned, centred, or bottom aligned. 99% of the people in my area align the leader with the centre of the first line of text. Why doesn't ArchiCAD have these simple adjustments?
2006-05-18 04:49 AM
Mike wrote:That's not the only problem with the label tool but it is a big one. It's not just graphic snobbery. A leader from the center of a block of text (unless there is a box around it) is not part of any graphic standard that I know and certainly no-one would have it point above or below the top or bottom line (again unless there is that box). Boxes around text notes is a rarity. Designing the tool to serve that purpose and not the far more common case is very bad design.Jere wrote:I have been wanting leader lines to align with the center of the first line of text for as long as I have been using Archicad and I know it has come up as a wish multiple times. Maybe in 11 Graphisoft can fix what appears to be a very simple problem that prevent some people (graphic snobs) from using the label tool. I use the label tool and hope I have mostly single line text
2006-06-06 04:37 PM
Mike wrote:Well count me in under the Graphic Snobs group.
2006-06-06 05:01 PM
Jere wrote:Yep. They do the same thing the rest of us do:
[Supposedly ArchiCAD was "made by architects for architects". Have these architects ever annotated a drawing?
2006-06-06 11:10 PM
