2021-08-24
04:46 PM
2023-05-22
11:50 PM
Gordana Radonic
2021-08-24 10:34 PM
2021-08-24 11:48 PM
2021-08-25 03:55 AM
2021-08-25 08:52 AM
2021-08-25 04:31 PM
2021-08-25 04:32 PM
Barry wrote:The lower wall will not dimension at all, not even itself.
I would have thought it was what Laszlo said - not parallel.
Try this, dimension just the lower wall.
Now select the dimension (keep the dimension tool active), and now CTRL click the side of the upper wall to add that dimension.
What happens?
If they are not parallel, no dimension will be added - you won't even get the 2 dimension nodes.
If you click on a wall node instead of the side of the wall, a dimension will be added.
2021-08-25 04:42 PM
4hotshoes wrote:Just start a brand new file, and copy-paste those Walls into it, then save it and put it on Dropbox, then post the link here.
How would I save just a part of the file?
2021-08-25 04:52 PM
2021-08-25 04:59 PM
