Dimensioning - Both Imperial and Metric Units?
Jeff Griffin
I realize that ArchiCAD dimensions can show either imperial OR metric units, but can it show BOTH imperial AND metric units on the same dimension string?
Thanks,
Jeff
iMac 27 (2020) 3.8 GHz Core i7; 128 GB RAM; Radeon Pro 5700 XT 16 GB GPU (macOS Sequoia)
MacBook Pro M1 Max; 64 GB RAM; 32-Core GPU (macOS Sequoia)
ArchiCAD 28/27/26/25 Full (back when Full used to mean Full) (latest builds). User since AC12 (2008).
Use the Secondary Dimension command.
Jeff Griffin
Thanks Laszlo. That's exactly what I was looking for.
Chazz
If I may be so presumptuous, Jeff, I doubt this is what you are looking for. What you are REALLY looking for (at least in the area of dual-unit dimensioning) is a tool that at the very least:
  • 1) Maintains associative relationships between the thing being dimensioned and BOTH sets of units (refreshing the units after the fact does not cut it).
    2) Automatically puts one of the units in (parenthesis) or italics or allows you to automatically predetermine some sort of differentiation between the units.
    3) Is not some tacked-on half-measure but something built into the basic functionality of the dimension tool itself.
The people of the United States of America and our proud (not to mention ironic) Imperial Unit partners in Burma and Liberia demand better!
Nattering nabob of negativism
