‎2004-03-19
09:34 PM
‎2023-05-30
03:28 PM
Rubia Torres
‎2004-03-19 10:13 PM
‎2004-03-19 10:45 PM
Tom wrote:No. The default display order position for each element type is hard wired.
Is there any way to set the display order for dimension to the top. I know I can do each dimension individually, or select them all and move to the top. But can I set it anywhere to always be on top.
How can I only dimension to one side of the wall. Every time I select one side of a wall, it dimensions both sides. I have the "dimension to core of wall" check box off in the dimension dialogue box.You have to click on a corner. It is the way of walls to do both sides. That said, I don't recommend it. (The corner.)
have a good weekend, ya'all.You too.
‎2004-03-20 06:51 AM
Matthew wrote:Similarly, with door & window marker leaders (the ones that should have customizable line types
I do the same as you, i.e. select all and bring to top. Not a big deal, but a minor pain when notes or dimensions disappear under a mask fill. It's much more of a problem when they don't show up on the printed drawings because someone forgot to do it.
