2020-03-25
12:11 PM
2023-05-19
03:46 PM
Gordana Radonic
2020-03-25 12:51 PM
another Moderator
2020-03-25 01:58 PM
2020-03-25 02:03 PM
another Moderator
2020-03-25 05:00 PM
2020-03-25 07:19 PM
another Moderator
2020-03-26 11:16 AM
ejrolon wrote:I use alt+f7 to place views on layouts so all views settings get set up automatically.
Definite a Bug since placing new Dims do not have the problem.
Work around use Pipette and Injection to update and they get fixed.
Also don't have "Custom" as part of your views, that means that they are not defined and you will get issues.
2020-03-30 01:11 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-03-30 02:39 PM
Minh Nguyen
GRAPHISOFT
2022-01-12 04:53 PM
Had the same issue with blacked out dimension text when using AC24 after updating a file begun in an older version. Removing the Solid Fill with Opacity set to 0% worked--thank you!
