2022-08-16 12:43 AM - last edited on 2022-09-28 07:38 PM by Oleksandra Vakariuk
Dimensions to hotspots in elevations and sections go missing when updating drawing on a layout. Attached is a video showing what's happening.
2022-08-16 03:29 AM - edited 2022-08-16 03:29 AM
Maybe it has something to do with renovation status?
You can't set it or change it in the hotspot settings.
But they will be set according to the renovation palette settings when you place them
You can also change them via that renovation palette.
I don't know why 'New' does not show in the info box.
This was in version 25.
2022-08-16 04:26 AM
I have also been encountered this dimension problem as well when using teamwork especially those MVO that goes missing... 😐
2022-08-16 04:33 PM
I've tested out different renovation statuses, model view options, graphic override combinations, and every other graphic adjustment that Archicad has. I thought it might be happening in a project that was migrated from 24 to 25 to 26 (this also happens in 25, but not in 24) so I tried the Archicad default template, and once it's teamworked then the dimensions disappear, but only until you open the section/elevation. If it's a PLN then there's no problem.
2022-08-18 04:47 PM
Update: Graphisoft has more or less confirmed it's a bug and are working on a fix. The workaround is to NOT dimension to hotspots in elevations or sections.
