2005-03-17
03:59 PM
2023-05-30
03:27 PM
Rubia Torres
2005-03-17 05:14 PM
Michele wrote:If you happen to chose a different element when you dimension (ie slab versus wall) the dimension will of course not update when you move the wall. I personally turn all layers off except what I want to dimension to. I have not seen an issue where the dimension will not automatically adjust.
I dimension something and then when I move it , the dimensions don't move and update with it. THis only happens sometimes. I must be doing something wrong or is this a bug in archicad? I'm using Ver 9 with the latest update.
Thanks,
Michele
2005-03-17 05:20 PM
2005-03-17 06:45 PM
2005-03-17 06:56 PM
2005-03-17 07:13 PM
2005-03-18 12:31 AM
2005-03-18 05:10 AM
2005-03-18 06:12 PM
Stuart wrote:Not necessary.
Instead of using an empty fill use a circular column with a really small height (ie 1mm or less).
2005-03-18 08:41 PM
