2025-01-05
07:41 PM
2025-01-06
08:36 PM
Hello everyone!
I don't know hot to describe my problem properly.
There's nice feature in AutoCAD where you can create new style of dimensions that can calculate size based upon certain scale.
For example, I made a working sheet with a section of a pipe. In plan view pipe is quite squigly but I need to create squeezed version of the pipe to exagerate it's slopes.
For example the scale of Y axis is 1:5 and the X axis is 1:40. The drawing itself is already done. But I can't use proper dimensioning because it calculates lengh based upon so to speak global scale of the working sheet. In AutoCAD it's a straight process of creating specialized style of annotation.
The only solution i came up with is to routinely change calculated dimensions with straight up typing.
Is there a way to solve this besides exporting it into AutoCAD?
Operating system used: Windows 10
2025-01-05 10:40 PM
In working with engineers I noticed their tendency to use different scales on drawings. E: a perfect square drawing might have one axis dimension written as 10 and the other is 765. Visually, the proportions are not correct but I understand where you are coming from.
as far as I know, Archicad can only use “real” dimensions (of the drawn element, drawn to scale) or you have to manually input your desired value on each dimension line - as an override of sorts.
2025-01-05 11:09 PM
For the moment I decided that it would be easier to create custom gdl linear dimension object that will calculate accordingly. It's a basic 2d shape so I guess it can solve the problem
