Wednesday
- last edited
Friday
I can't figure out how to display window tags on exterior elevation. I've always just shown them in plan, but I have a need for them to be on the elevations as well.
Thanks in advance.
Phil
Operating system used: Mac Apple Silicon sequoia 15.6.1 (24G90)
Solved! Go to Solution.
Wednesday
- last edited
Friday
You can use an associative label, and then select the Door Window label that is loaded into your version of Archicad you are running.
Wednesday - last edited Wednesday
You can use the Property Label Type or Opening Label and change the frame shape, text, etc. to match whatever you need and save it as a favorite.
If you want to label all the windows at once in the elevation view:
Wednesday
- last edited
Friday
Wednesday
Awesome - thanks so much!
