Hi!
Thank you!
In the beginning, I preffered to have a marker in that form, because its a big project with many windows and doors, that its easier if you can select alle the windows and assign the one marker to all of them at once. But when I lost the hope, I tried building a new label for the doors and windows (draw something and save as label). But as I tried to explain in the first post, I couldnt find the correct autotext, which I could use as „second“ ID field. And then it was also rotating and was beeing squeezed in a wierd angle.. I will try playing around more next week, when I will be at my desk again.
Thank you again!
