Door in Curtain Wall does not show anymore in plan but does in 3D.
12LKS202512
My doors in the curtain wall plan won't show up, they were there and disappeared after I fixed the frame widths and added a transom above each door. The 3D shows them but not the plan. I tried the projected feature, and the show full, in place of MVO and I tried the show lines and checked the angle is at 90 deg. Still nothing. The work sheet is the reference underneath the plan, (to avoid confusing you) in the attachments.
Operating system used: Windows 25
cuba
Can you check if the doors are visible when you lower the floorplan cut plane?
Docment/floorplan cut plane
Apple M1 Max 32 GB Ventura
AC27
4 REPLIES 4
There are no attachments.
cuba
AC27
HI No change I'm afraid, its funny that when I go into edit mode click projected, then I see them and after I exit they disappear, (my setting is projected but when I reenter edit mode it's back to Symbolic.) It wont take projected and keep it.
