Door shown at 45 degree angle
dhnguyen
Where do I go to change the setting of the door so that it shows the door swing at 45degree angle instead of 90 in plan view? I have been looking in "Door Selection Settings", but can't find it.
Thanks.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
vistasp
Apart from changing it graphically (using a hotspot) for a single door, you can change it in the parameters as well. If you're using doors from some other library, this might not be the case.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
6 REPLIES 6
vistasp
= v i s t a s p =
bT Square Peg
dhnguyen
Thanks for the screen shot, that helps a lot. So I went into "Opening" tab under "Custom Settings", and changed the "Opening Angle to 45 degree and it works, thanks!
DNguyen
ArchiCAD 18- 25
vistasp
Glad it helped. So this was a non-GS library part?
= v i s t a s p =
bT Square Peg
dhnguyen
It's one of the doors from the standard library. Here's where I found it based on your screen shot. - see attached.
DNguyen
ArchiCAD 18- 25
vistasp
You seem to be using multiple older (and very old) libraries at the same time... Any particular reason?
= v i s t a s p =
bT Square Peg
Erwin Edel
The load times for all those libraries and loading errors must be horrible
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
