Doors NOT showing handles in ELEVATION only , showing in 3d
cocoloco
Hi! I have a strange situation. Doors are set up well, and showing handles in 3D, but not in elevation.... I checked model views, doors setting... can't find what's the issue this time..
Operating system used: Mac Intel-based
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
BrunoH
Hi cocoloco,
In MVO, did you check this one?
ArchiCad 3.43 to 28
MacOS Monterey
Lee Hankins
Have you checked the settings in Model View Options under Detail Level of Doors, Window and Skylight Symbols to make sure handles are turned on in elevation?
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
I had all on. Believe it or not..... after restarting archicad, all of the sudden we can see now handles.. Very interesting
BrunoH
Hi cocoloco,
ArchiCad 3.43 to 28
MacOS Monterey
Setup info provided by author
