In my Publisher Set, I have my drawings to save as PDFs yet I get different pen weights on two different saved PDFs. In the size of 8 1/2" x 11" I get the desired pen weights, yet when saved in the format of 24" x 36" one particular pen weight is obviously heavier. Within Properties, both utilize the same Pen Set, and Colors are defined as "Colors defined by Pen Set". When viewed in Navigator - Publisher Set, the weight appears visually correct but when saved and opened in Adobe Acrobat it publishes heavier. Is it possible the different sized format makes the difference?
Thanks in advance for the help.
MacBook Pro
Intel Core 2 Duo Processor
Speed: 2.5 GHz
still on version 10
