Drawings not being cropped properly
Hi everyone,
Recently i've been noticing this really nasty bug.
When on a layout or in workspace different drawings are partially hidden the numbers in the hidden sections remain. Please see the screenshot for reference.
bug
Is there a way to fix this?
Thank you!
Operating system used: Windows 27.2
It was supposedly fixed in 27.2.1 and I am sure I saw posts here with people saying it was fixed.
I still have 27.2.1 installed and that appears to be working fine.
I have just updated to 27.2.2 and that seems to be working fine when cropping layouts as well.
I am not sure about worksheets as I do not use them.
If you are sure that it is not working then you should contact your local support to report it.
4 REPLIES 4
Botonis
Mentor
Which version are you using. There was a similar bug but was fixed with an update in 27.
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
I'm using 27.2.2
My bad, I had forgotten to update after downloading the file.
it works good now.
Thank you!
Setup info provided by author
