Drawings not being cropped properly
Hi everyone,
Recently i've been noticing this really nasty bug.
When on a layout or in workspace different drawings are partially hidden the numbers in the hidden sections remain. Please see the screenshot for reference.
bug
Is there a way to fix this?
Thank you!
Operating system used: Windows 27.2
It was supposedly fixed in 27.2.1 and I am sure I saw posts here with people saying it was fixed.
I still have 27.2.1 installed and that appears to be working fine.
I have just updated to 27.2.2 and that seems to be working fine when cropping layouts as well.
I am not sure about worksheets as I do not use them.
If you are sure that it is not working then you should contact your local support to report it.
4 REPLIES 4
Botonis
Mentor
Which version are you using. There was a similar bug but was fixed with an update in 27.
I'm using 27.2.2
My bad, I had forgotten to update after downloading the file.
it works good now.
Thank you!
Setup info provided by author
