2023-06-26 05:47 AM
Is there a way to create a custom Project Info Section so that I may have a custom set of inputs other than the Add option at the bottom of the window?
Can this be done via an XML editor or something?
2023-06-26 09:38 AM
Project Info import and export options - Graphisoft Community
| Archicad 4.55 - 27
2023-06-26 11:41 AM
Double reply here - I have posted this in Miha's post as well
We have used XML Notepad which is easy enough and gives a reasonably simple way of handling ProjectInfo entries.
We think it works well and solves some of our problems.
Still, a better way of handling ProjectInfo - including the possibility to map in IFC as been discussed in other threads.
