Editing Project Info
Too Long
Is there a way to create a custom Project Info Section so that I may have a custom set of inputs other than the Add option at the bottom of the window?
Can this be done via an XML editor or something?
AC26 AUS Full
Miha_M
Project Info import and export options - Graphisoft Community
| Archicad 4.55 - 27
Erik Bjornhage
Double reply here - I have posted this in Miha's post as well
We have used XML Notepad which is easy enough and gives a reasonably simple way of handling ProjectInfo entries.
We think it works well and solves some of our problems.
Still, a better way of handling ProjectInfo - including the possibility to map in IFC as been discussed in other threads.
Erik Bjornhage : SwedishChef, ETTELVA Arkitekter, Gothenburg, Sweden
Architect : Digital Development : Graphisoft Cert. BIM-Manager
ETTELVA Arkitekter : Eriks LinkedIn
DELL Precision 5570; i7-12700H; 64 GB; RTX A2000 [8GB] : AC12 - future
