2011-01-07 06:47 PM - last edited 3 weeks ago by Molinda Prey
2011-01-08 07:35 PM
2011-01-10 02:55 AM
2011-01-13 01:48 AM
2011-01-13 05:03 PM
2011-01-13 05:07 PM
2011-03-01 08:05 PM
2011-06-16 10:06 PM
vfrontiers wrote:I do not understand the "save selection" comment?
Very strange. I recently did the same task (renumber doors) using this concept and it went the way I wanted it to each time...
Also, I wanted to point out that if you make your ORDERED SELECTION... go to the SAVE SELECTION palette and save it... next time you want to number again, you can load this selection with the same order...
2011-06-16 10:24 PM
2011-06-17 01:51 AM
vfrontiers wrote:What if you ADD a door or window in the
Per my tests, it does maintain the ORDER in which you selected them, so using this technique to select doors to renumber should give good results after a door goes away (for example)...
