2023-08-25 10:55 AM
Hi, I was editing my elevation drawings in 2D. I changed some of my fills to grey for shading but they show up as black or a different colour on my layout sheets. How do I align my pen sets so that layout pen set is the same as my drawing pen set ? Is that possible ?
Thank you in advance.
Solved! Go to Solution.
2023-08-25 11:10 AM
In the settings for the drawing you have placed on the layout, you can choose the pen set you want to use.
This overrides the pen set used in the view.
You can set it to "By View" so it will always use what has been set in the view or you can chose a particular pen set.
So you can see here my view uses the pen set "JWH Standard" but I override it with "JWH Layouts - black/grey" as I always want them to appear and print black on the layouts (with some colour pens when I need them).
2023-08-25 11:10 AM
2023-08-26 04:25 AM - edited 2023-08-27 11:41 AM
Awesome !
By view is my preference but now that I know what dialogue box to use I can set it up.
Thank you for the help once again.
Edit: It was my fault for not setting the solid fill pens correctly. I learned more about drawing settings and viewing the sources for the elevations layout from my mistake above.
