Josh Verran
Elevation Style Showcase
Apologies if there has already been a post similar to this, but curious to see what elevation styles people use around the globe. Below are a couple of examples that I use, it's not a real project, more just enough elements to show use of colour, hatches etc.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
4 Replies 4
Hello Josh Verran,
In France about dwellings, below a sample all in black and white because more practical for reprography and graphically more impactful (automatic labels on windows and shadow stripe hatches).
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
DGSketcher
Legend
@Josh Verran You might have seen a better response if we could assign Styles to Views rather than the current restrictive workflow of assigning a single style to each Elevation/Section marker. I would imagine for many, that assigning multiple markers to the same elevation to display different graphic styles is reserved for well paid or managed projects. Placing a single marker and making it work using GOs for as many views as needed is possibly the default option.
Josh Verran
Nice! I like the hatch you have chosen for shadows.
Josh Verran
Yeah I've tried a few methods, one marker two Graphic Override Combinations, but found I couldn't quite get what I was after. Tried two different markers but then one would get altered (extents) and staff would wonder why the other hadn't updated.
Have settled now for one marker, but have a favourite setup for BnW and another for Colour.
