Elevation Window Becomes "Independent"
Aaron Bourgoin
My elevations have been transformed into something I've never seen before: an "independent" elevation.
No markers and no editable settings.
Can anyone tell me what might have happened here?
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.1 USA
Rhino 8.25 Mac
MacOS Tahoe 26.1
6 REPLIES 6
Erika Epstein
A little more information?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Eduardo Rolon
My guess is that you deleted the markers either by selecting them, deleting thier layers or by editing using Attribute Manager.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Aaron Bourgoin
last thing I recall doing was placing 1:100 views on layouts, cloning the elevations folder to make enlarged elevations and placing those.
I do not recall having done anything to marker settings, but perhaps I did.
I've made new elevations and am carrying on.
I'm remarking about this as I have never seen the term 'independent' applied to anything other than details and worksheets. My elevations were all live to the model and then became static line drawings with no associated markers.
MacBook M4Pro
Rhino 8.25 Mac
MacOS Tahoe 26.1
Eduardo Rolon
Pop Up that appears when you delete a marker
AC29 US/INT -> AC08
another Moderator
Aaron Bourgoin
I must have had slippery fingers that day. Thanks!
MacBook M4Pro
Rhino 8.25 Mac
MacOS Tahoe 26.1
Also, if you select an Elevation Line, go to its Settings Dialog and set its type from "Source Marker" to "Unlinked Marker" then its corresponding Elevation item in the Project Map will become an Independent Elevation.
You can then link that Marker to that independent Elevation but you can never again make it a Source Marker.
