2019-07-1110:59 AM - last edited on 2023-05-2303:05 AM by Gordana Radonic
2019-07-1110:59 AM
In my elevation view I don't have a frame. and it looks like if I drag an object to far up I it disappears. I have set project 0 to 0, and my sea level is at 20 000mm for some reason. which meant that everything I have drawn at 70 000mm above project 0 disappears in my elevation view
Is there a Vertical Range defined for your Elevation?
If it is then it can cause elements to disappear (not displayed) in the Elevation if they are higher than the upper limit of the Vertical Range.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
