‎2004-02-26
08:11 PM
‎2023-05-17
12:57 AM
Gordana Radonic
‎2004-02-26 09:13 PM
‎2004-02-26 11:00 PM
Tom wrote:I've been doing it by drawing new lines (saved in Favorites) on a separate layer in each elevation.
What is the best way to show thinner/wider lineweights in elevation so the drawings appear closer to farther away.
I've done it in section, but nothing seems to work in elevation. Is that something I would have to set up in the pen weights in each wall? That would seem to be very time consuming.
‎2004-02-27 08:01 AM
Dave wrote:As Matthew said, Distant area option in the Section?Elevation settings does quite a good job. Expecially when you combine it with the shadows, as you can separately set the shadows for the distant area (different fill, different pens).Tom wrote:I've been doing it by drawing new lines (saved in Favorites) on a separate layer in each elevation.
I've done it in section, but nothing seems to work in elevation. Is that something I would have to set up in the pen weights in each wall? That would seem to be very time consuming.Very non-BIM! If there's a better way, I'd love to hear it also.
‎2004-02-27 08:32 AM
Djordje wrote:I agree--drawing over the S/E is not a BIM ideal. But when there are several building planes receding into the distance, I want to show each plane with progressively thinner outlines, and that was Tom's question. I know of no other way of achieving this than re-drawing.
You should try not to draw over if possible ...
‎2004-02-27 01:26 PM
‎2004-02-27 02:47 PM
‎2004-02-27 05:26 PM
Tom wrote:This has been posted by Duane on the old Talk years ago, and AFAIR was even living somewhere in the Archiguide files ... but, Matthew, please do post the technique under a new topic!
Matthew:
I'd appreciate it if you would post the technique. As a new user, I don't know the advantages/disadvantages of keeping the elevations linked versus unlinked. I guess it depends if you anticipate a lot of changes. One of the reasons I changed from AutoCad was the linked solution to elevations.
Could I combine some of the above noted solutions. For example, could I do the distant area marked operation, then unlink, then do your solution to work the outlines. I assume you would be able to change the pen weight of the fill outline.
‎2004-02-27 06:22 PM
Tom wrote:Be aware that even after you unlink a S/E, you can rebuild from the model whenever necessary. Any 2D linework you've added in the drawing will be unaffected.
Matthew:
‎2004-02-27 06:24 PM
Matthew wrote:Neat trick indeed, Matthew. Please do post when you get a chance.
I have found a neat trick I call shrink wrapping. It goes (briefly) as follows...
If people are interested I can post a PDF showing the technique later when I get to the office.
