Elevation name text postion
Too Long
Hi all.
How can i show the GF Ceiling text below the line whilst maintaining the other text above the line?
AC26 AUS Full
The horizontal line and the text are created by a GDL object called "Built-in Story Marker".
It does not provide this capability of modifying the position of the text from its default.
You would probably have to script your own in GDL.
Or, you can try this very capable and free Story Market object from Indigofigs:
https://www.indigofigs.com/story-marker/
Too Long
Thank you very much for your response
AC26 AUS Full
