Elevations in View Map deleted by mistake
Whilst cleaning up obsolete views etc, it appears that the Elevations in my View Map have been deleted by mistake.
This seems to be independent of undo as I noticed and couldn't rectify it.
The elevations are still on my layout but I'm not sure how to sort everything out/what implications this might have.
This is my first project in Archicad so I'm still getting up to speed on the organiser/navigator etc
15 REPLIES 15
Go into the project map right click on each elevation & save current view, they will then re-appear in the view map only at the bottom, you will need to drag them up to the folder where you keep them.
Thanks, will do that tomorrow
You will then need to re-link the drawings on the layouts to those new views.
Or just delete them and place the new views on the layouts again.
They are only views of the elevations and the original elevations are still there in the Project Map.
So no real harm done - the hardest part is remembering the settings for the views when you re-create them.
Bruce
A quicker way to create the views is to open the Organiser, then drag all the relevant elevations from the project map on the left, to the view map on the right, then change the settings of them all at once whilst still selected.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Thanks everyone.
What's the best way to relink the elevations on my layout please
Select the drawing on the layout, right mouse click, link drawing to...
Sorry Barry, I meant vice versa.
They're on my layout but deleted elsewhere. I just wondered if there was a way of restoring the elevations that are on my layout
You have deleted the view, so the drawing on your layout is effectively fixed now - no longer linked to anything.
There is no way of re-establishing the view from the drawing on the layout.
You will have to re-create the view and then either re-link the drawing on the layout to that new view or delete the old drawing and place a new one from that view.
Thanks for clarifying Barry.
If I relink back to the now recreated views, will they override the current appearance of the fixed views on the layout?
