Ellipse basin does not show up in PDF
Is this a bug?
We've used several casework objects from ArchiCAD 14 Library and we just noticed that the ellipse basin does not appear on our published PDFs. The round basin of the SAME object shows up. The double sink from the cabinet object shows up too. Seems like this could be isolated to the ellipse basin only.
I've attached an image in which was copied from a published PDF in Adboe.
26 REPLIES 26
Steve wrote:
.... I tried to print and publish with different .pdf settings. Ellipse seems to work fine with any scale sensitivity setting. I also tried printing from the floor plan and from the layout.
This is how you can be sure what the Publisher is using to generate the .pdf's
Does it make a difference if the publisher is set up to use the Amyuni or the Acrobat? It did not make any difference for me.
Since I was using the default Layouts to PDF publisher set, the setting is to save the layouts as a PDF file. That's probably where the issue is occurring. Can you confirm?
Printing from publisher using either Adobe PDF or Amyuni worked.
I apologize for my wording - I always seem to think when it comes to PDFs, printing, publishing or saving is almost the same thing.
It failed!
That was a suprize. I changed to the Amyuni and used Save to publish.
The ellipse is missing.
Thanks a bunch Steve. For not only making me feel no longer alone in this (ha) but also for going back and forth with me, helping steer me in the right direction down all the way to publisher set settings and output format!
I've sent a follow up email to Graphisoft US pinpointing the location of this issue/bug and hopefully they will fix it with the next hotfix.
Erika Epstein
I can't duplicate the problem. Just published this from 14.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
But you're using Mac I assume. Looks like a PDF print driver problem.
Erika Epstein
Matthew,
I tried on a pc that matches his specs. I can reproduce the problem
only with mirrored instances AND when in TW2.
Is that a print driver problem?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erika wrote:
Matthew,
Who knows? Definitely odd. Remarkable that you managed to narrow it down so precisely.
Sounds like something for GS to sort out. I guess the workaround for now is to un-mirror the offending parts.
This is still a problem in the latest hotfix (publishing a mirrored ellipse with the built in PDF convertor).
I have reported it to GS Australia but if GS HQ see this can it please be fixed in the next hotfix.
It used to be a problem some versions ago (maybe 10?) and got fixed then.
It is not always convenient or easy to un-mirror an object espescially if it is not symmetrical.
I also have this problem.
