‎2005-03-17
06:38 PM
‎2025-02-10
04:05 PM
Aruzhan Ilaikova
‎2005-03-19 11:52 AM
‎2005-03-19 02:34 PM
Stig wrote:No, as this increases the layout book file size significantly. I have been in contact with graphisoft technical support and they agree that this is probably a bug that is caused by having the current PLN file open on a different machine than is updating the plotmaker layout book. It would seem that you should either be locked out from updating a PLN if someone else has it open or it should update correctly; just as it would if the PLN was open on the same machine that was performing the update.
Did you set the preferences/cache folder in PlotMaker to "include cache in the layoutbook"?
Stig
‎2005-03-19 04:09 PM
‎2005-03-19 06:52 PM
Stig wrote:This is true until the next user updates the file. Then their cache will include the PMK files as well.
... If another user opens the .LBK on another workstation, the file doesn't have access to the PMKs unless the cache is included in the layout book.
Stig
