Thanks Erwin. Will look at renovation status filters, I may not be understanding correctly.
I am seeing no option to tick or untick anything but 'new', 'existing' and 'demolished' status in CI schedule manager criteria tab.
Is there a way to add another status type to ArchiCAD?
Are you using the CI schedule system, or just standard GS Schedules menu schedules?
if a door in your module source walls has a renovation status such that it appears in your 'module workspace' renovation filter, wont this status just propagate into modules, meaning doors in modules will not schedule/ any differently to doors in source walls?
I was not sure what you meant by 'pin', but guessing it relates to this - do you switch all doors temporarily from 'demolished' to 'new' status before saving modules, then switch them back afterwards? Then have CI schedule set to only schedule 'new' doors?
All my modules are multi story, (as is the project) and there are a lot of them, though I guess I could do a 3D marque around the whole modules working area, save this as a 3D view, then do global doors and window renovation status toggles from that view
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
