Johann_P
Export multiple layouts to DWG
I have spent the last hour reading articles and watching youtube, and am still none the wiser.
I'm trying to export multiple layouts via the publisher set to DWG, but I cant seem to locate the setting to do so.
I only seem to have a "save to pdf" option.
What am I missing?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
4 Replies 4
DGSketcher
Legend
@Johann_P Shot in the dark as I am not on Windoze. Is there any possibility you have embedded PDF content in your layouts e.g. Logo or image? Just wondering if that would force the options to be limited as I'm not sure DWG export can handle embedded PDFs.
Gerry Leonor
it's in your Publisher sets.
you can select the top-most folder of the Layouts & select the DWG export. just make sure your DWG translator has the settings you want.
https://discord.gg/XGHjyvutt8
Gordana Radonic
Community Manager
Community Manager
Maybe reply to this post also helps, it's a similar problem:
https://community.graphisoft.com/t5/Collaborate-forum/How-to-export-a-drawing-from-an-Archicad-layou...
Gordana Radonić
Community Manager
Check Gerard Leonor's attached image. It shows that when you select a folder, the "Merge to one DWG file" checkbox appears towards the bottom of the Palette. Try to check that.
The trick is that you have to select a folder. Then all individual Layouts within that folder should be saved into a single DWG file, and if your DWG Translator settings are correct ("Save Layout Into" field, then in the DWG file, separate Paper Spaces should be created from each of those  Layouts (if I remember correctly).
