FRAMING ADD ON
I got this to work for a wall running across the screen but not one running up the screen.
Also it does not seem to conform to a wall with a sloping head.
Are these things beyond its capabilities?
2 Replies 2
I assume you are talking about a CadImage Tool, Bruce? What version of AC?
__archiben
again, assuming cadimage wall framing:
is your wall running up the screen a composite with a framing system defined in the composite wall settings?
i haven't used it for a while, but i seem to recall that sloping heads would only work with walls that have been 'trimmed to roof' rather than 'SEO'd...
more info . . ?
~/archiben
b e n _ f r o s t
