File association to Archicad 10
I can't seem to hook up .pln files to open with a double click in version 10. When I browse to "open with" I can go to the Archicad10.exe file but it doesn't hang on to it.
If I go to the individial file properties, same thing, I can go pick 10 but it doesn't come into the "recommended programs" list so that I can highlight it.
Any suggestions? I'm tired of opening the program and then opening the file, that's an extra step. Thanks.
16 REPLIES 16
Sounds like a registry problem. I haven't run into this myself so I'm not sure if there is a quick fix or if it takes a reinstall (nor whether that would do the trick). Does it work to drag and drop the file to an ArchiCAD shortcut or taskbar icon?
That takes me to 1.5 steps. Good progress. Anyone have any registry suggestions, or other?
TomWaltz
What does Windows try to open PLN files with, if not Archicad 10?
Tom Waltz
Link
ArchiCAD 9 I bet.
2 ways I know of: Right click on the file > Open With > Choose Program... > (choose AC10) and check 'Always use the selected program to open this kind of file'. Or in Windows Explorer go to Tools > Folder Options > File Types, scroll down to PLN (click in the list and hit the P key a few times) and hit the Change button. This just take you back to the first method though!
Hope there's not more to it than that!
Link.
Dwight
CTP Scene Definition
FLight Simulator
Home Plan Pro Architecture Design (yikes !!!)
InDesign Plug In
Psion Organiser
RealFlight Radio Control
WordPerfect (formerly Planperfect) Spreadsheet
You can look up any extension here:
http://filext.com/
Dwight Atkinson
anyway I approach it, through individual files, through folder tools, I can't make 10 stick as the preferred program to open it with. I can browse to it, but it won't bring it to the list of programs to pick.
TomWaltz
FLight Simulator
InDesign Plug In
Psion Organiser
http://filext.com/
I kind of meant that for Derek, what HIS machine was trying to use.
Tom Waltz
Dwight
Sure, but it is astonishing how many obscure programs use .pln.
Dwight Atkinson
__archiben
http://filext.com/
*.VBM is unused. graphisoft should act now and change all PLN/PLP/etc extensions to VBM!!!
~/archiben
b e n _ f r o s t
