2022-01-19 11:38 PM
Hello, I am pretty new to Archicad and I may not understand everything that well. The problem is that i've made floors in my project and while viewing it from the top, the structure of the materials doesnt show. I don't know how to describe the issue that well so i'll be adding a screenshot. Some of the flooring in my project is made for example out of tiles and in this view every floor looks the same. Please and thanks for help.
2022-01-20 02:30 AM
Unless this has changed in AC24/25, the representation of floor finishes is controlled by the Cover Fill of the relevant floor / slab / etc. By default this is set to match that of the top surface, in which case the pattern can be defined under the individual surface settings.
Options => Element Attributes => Surfaces => [Relevant Surface] => Vectorial Hatching
Ling.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
