Floor won't connect properly to walls
I'm having difficulty getting the floor in my Archicad model to connect properly to the walls. The floor and walls won't merge properly and there is therefore a line in the facade which I'd rather not have. I've been using Archicad for a year and have never experienced this problem before. Does anyone know what setting I need to tweak/ what I could be doing wrong?
I'm also struggling to get my sections to have a grey fill but have all my normal settings filled in. I.e. In properties the 'cut fill foreground and background' pen is grey yet the section appears white.
Attached is a picture to show what I'm referring to. Hopefully some has some good tips!
Thanks!
1 Solution
David Maudlin
Probably either the wall or slab edge is slightly out of alignment. Zoom way in at the corners with the display set to Hairline and check if the wall or slab edge is not orthogonal.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Go to post
2 Replies 2
David Maudlin
Thanks David!
