2019-12-04 09:50 AM - last edited on 2023-05-30 09:56 AM by Rubia Torres
Solved! Go to Solution.
2019-12-04 02:59 PM
annaebb wrote:Probably either the wall or slab edge is slightly out of alignment. Zoom way in at the corners with the display set to Hairline and check if the wall or slab edge is not orthogonal.
I'm having difficulty getting the floor in my Archicad model to connect properly to the walls. The floor and walls won't merge properly and there is therefore a line in the facade which I'd rather not have. I've been using Archicad for a year and have never experienced this problem before. Does anyone know what setting I need to tweak/ what I could be doing wrong?
2019-12-04 02:59 PM
2019-12-05 05:22 PM
