Font showing up incorrect.
Ace
When I open an archicad job from my home computer the font shows up larger and outside of the text box frame. I was told it could be I was missing font Arial Unicode MS Regular. I have since install that front but hasn't fixed the problem. Any ideas on how to fix?
runxel
Hero
In the screenshot it says "[Arial Narrow]".
The square brackets mean that this font is missing.
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
9 REPLIES 9
Hello Ace,
Are you sure it is the right font ?
Did you try to change this font by another one ?
Did you restart Archicad ?
Are you working on a windows device after a macOS device ?
Christophe - FRANCE
Formateur Archicad indƩpendant Ơ NANTES
Archicad 15 to 29 FRA FULL
If you are on a Windows PC, check your operating system display settings.
See if you have scaled the text size.
If so set it back to 100% (you may need to restart Archicad - possibly the machine).
runxel
Hero
Ace
Thanks Barry,
I checked my windows pc settings and it was set to 100% already.
Ace
Thanks runexl,
That could be it. I can't find it in the arial narrow in my font's folder. I'll try downloading and see how I go.
It is as Runxel mentioned.
You do not have the "Arial Narrow" font installed on your machine - that is why the font name appears in square brackets.
It has nothing to do with "Arial Unicode MS Regular".
It will be substituting Arial for it which is a wider font than the space allowed.
Ace
Thanks everyone. I was missing the arial narrow font.
Hello, i am having the same problem. This happend out of the blue, worked ok until today. Now the font is in square brackets but when i search it in the windows fonts my font used is there as available and installed.
So what could have happened?
drexdis wrote:
Hello, I am having the same problem. This happened out of the blue, worked ok until today. Now the font is in square brackets but when I search it in the windows fonts my font used is there as available and installed.
1. Try to restart Archicad.
2. If that does not help, try to restart your operating system.
3. If that does not help, try to install the font in the operating system, restart, reinstall the font, and see if that helps.
