2006-05-03 03:24 AM - last edited Wednesday by Molinda Prey
2006-05-08 06:51 PM
s2art wrote:Theoretically... (don't remember if I tried it, but I think I did) shouldn't it work to just open the first view, and then redefine all the other views without opening them? I would think that since you're only changing the settings, you should not have to open each view in order to redefine it.Scott wrote:
I just had a case where I had merrily set up 12 elevations (3 ele's of 4 options), saved the views, discovered trnasparency was on, I had to go to each saved view, change the 3D window settings to "transparency - off", close the 3D window, redefine the view, do the next one...
2006-05-08 10:42 PM
Sergio wrote:Yes, except you don't need to open any particular view at all. In the view editor you can select any number of views and redefine them all to the current settings. Besides scale and display options this will also reset the dimension settings and 3D transparency. Naturally it is usually best not to select views of different types when you do this.s2art wrote:Scott wrote:Theoretically... (don't remember if I tried it, but I think I did) shouldn't it work to just open the first view, and then redefine all the other views without opening them? I would think that since you're only changing the settings, you should not have to open each view in order to redefine it.
2006-05-09 02:41 AM
2006-05-09 03:27 AM
s2art wrote:No, only its settings apply (Layer Combination, Scale, etc). There is no way to change the source View of a saved view.
Is it not the case that if you have view A open, redefine it, select view B from your view set (but don't open it) then redefine B, it is now the same as view A?
