Robert Nichols
Graphic Overrides - hide/show ?
I'm just starting to experiment with Graphic Overrides. When Renovation filters arrived in 19 (18?), I thought they were a great solution to a tricky problem (demo plans), so I was eager to see their logic extended.
But..I'm not seeing a means to hide elements using the Graphic Override controls. I had expected I could control visibility of any element I could identify with selection criteria. My specific task was to create a series of construction sequence views. The elements I wanted to show up sequently would have ID's of something like seq1, seq2, etc. Being able to filter and control visibility with Graphic Overrides would avoid a proliferation of single-purpose layers and layer sets.
I went back into the Renovation dialogs to see if I could solve my problem there, but the show/hide/override filters appear to act only on the 3 possible values of the Renovation Status field. So, I suppose to could do something inelegant and call my first sequence "existing", my second sequence "demo" and my third sequence "new construction," but then I'm out of sequences.
Was I expecting too much from GI (though I do appreciate their obvious intended purpose)? Is the functionality I'm seeking there - and I'm just not seeing it?
Thanks.
Mac Studio, 32gb ram, ArchiCAD v26 (Apple Silicon) MacOS 13
This is something that has been brought up multiple times before. Unfortunately, Graphic Overrides do not have a HIDE option which would enable one to hide or make invisible elements meeting specific criteria.
You can try to override those elements with a white Pen outline and invisible Fills.
