Graphic override displays correctly in model space but not on pdf?
I am trying to override door tags for a portion of a project. I started by creating identical door tags that have different names so that I can create graphic override rules that turn them white on the plan (i.e. not visible when printing). That all worked in model space. However, when I placed that view on a PDF the graphic override does not work?
Any ideas?
Thanks,
1 Reply 1
Check the settings for the view (drawing) that you have placed on your layout.
It may not be set to use the door tag hidden GO.
This is assuming you are publishing your PDF from a layout.
